Nếu không bị cao đường thì chị Sơn thử 1 muổng đường coi có hết bị nấc cục như trong phần 5 dưới đây không:
(nếu hết nhớ thưởng, bằng không cũng cho biết để em đi kiếm cách khác!)
8 Home Remedies that Actually Work
By Woman's Day | Shine's Guide to Great Skin – Tue, Feb 21, 2012 6:03 PM EST
By Brynn Mannino
http://shine.yahoo.com/skin-guide/8-hom ... 00122.html
Nobody is naysaying the wonders of modern medicine-what would we do without a medication like penicillin to treat infections? But, as it turns out, everyday items have secret curing powers, too. Next time you don't want to fork over money to get a common wart removed, consider using duct tape. Already popped two aspirin but can't get rid of the headache? A pencil could do the trick. Below, get medical explanations behind a few bizarre-albeit brilliant-MacGyver-esque home remedies.
Duct Tape to Remove Warts
Photo: Thinkstock
In 2002, a group of doctors compared duct tape's effectiveness with liquid nitrogen in removing warts. After two months of wearing duct tape on a daily basis and using a pumice stone about once a week to exfoliate the dead skin, 85 percent of patients' warts were gone, whereas freezing only removed 60 percent. "The question is whether there is something in the chemical adhesive itself, or if the occlusion (suffocation) causes the destruction of the wart," says New York City-based dermatologist, Robin Blum, MD. "The other thinking is that the duct tape causes irritation, which stimulates our body's immune cells to attack the wart."
Learn 4 ways to fight cold sores.
Vapor Rub to Cure Nail Fungus
Photo: Thinkstock
While there are no studies to prove coating infected toenails with vapor rub once or twice a day is an effective treatment for nail fungus, a basic Internet search results in a number of personal testaments to the medicinal ointment's fungus-killing powers. "I've heard many patients say that vapor rub does help, but I'm not exactly sure why," Dr. Blum admits. While some argue it's the menthol in the balm that kills the fungus and others say it's the smothering effect of the thick gel, if used consistently, vapor rub has been shown to get rid of not just the fungus, but the infected toenail, too, which will turn black and eventually fall off. When the new nail grows in, it should be fungus-free.
Oatmeal to Soothe Eczema
Photo: Thinkstock
"This is absolutely true, as oats have anti-inflammatory properties," Dr. Blum says. Whether it's used as a paste or poured into a bath, most experts recommend choosing colloidal (finely ground) oatmeal and soaking the affected area for at least 15 minutes. In addition to reducing inflammation, oats are thought to have an antihistamine effect, Dr. Blum says. By lowering levels of histamine, which triggers inflammation as part of the immune system's recovery response, she explains, oats prevent or reduce the redness.
Check out these simple itchy-skin soothers.
Yogurt to Cure Bad Breath
Photo: Thinkstock
Bad breath comes from a number of places, the two most common being the mouth and the stomach. The neutralizing powers of yogurt and other probiotics treat the latter cause. "Yogurt shouldn't have any effect at all on the bacteria that live on the tongue because it's not there long enough," says Robert Meltzer, MD, a New York City-based gastroenterologist and attending physician at Lenox Hill Hospital. However, it likely has a neutralizing effect on the acid that resides anywhere between the mouth and the stomach, including the back of the throat and the esophagus, he explains. "I think almost any milk product or food that contains live cultures would have the same effect." While yogurt can get rid of bad breath that results from gastrological conditions, like acid reflux, it won't have any real effect on bad breath that is the product of gum, liver or lung disease, says Ohio-based dentist Matthew Messina, DDS.
A Spoonful of Sugar to Cure Hiccups
Photo: iStockphoto
In 1971, Edgar Engelman, MD, conducted a study to find out if a spoonful of sugar really is an effective cure for hiccups. He assembled a group of 20 patients who had been experiencing intractable hiccups for more than six hours, eight of whom had had them anywhere from a full day to six weeks. Each of the test subjects was given one teaspoon of white granulated sugar to swallow dry, and for 19 of the 20 hiccup patients, the cure was immediate. André Dubois, MD, a gastroenterologist in Bethesda, Maryland, noted in The Doctors Book of Home Remedies that "the sugar is probably acting in the mouth to modify the nervous impulses that would otherwise tell the muscles in the diaphragm to contract spasmodically."
Find out what causes hiccups and more.
http://us.lrd.yahoo.com/_ylt=Ai5IOJ4M0w ... %26mag=wdy
Bite a Pencil to Cure a Headache
Photo: Thinkstock
While doctors aren't sure why we do it, clenching our teeth is a common side effect of stress. According to Fred Sheftell, MD, director of the New England Center for Headache in Stamford, Connecticut, when we clench up, we strain the muscle that connects the jaw to the temples, which can trigger a tension headache. By placing a pencil between our teeth-but not biting down-we relax our jaw muscles, which eradicates tension and reduces pain. Just remember, the remedy really only applies to tension headaches-not migraines or headaches caused by sinus pressure, etc.
Olives for Motion Sickness
Photo: Thinkstock
According to the National Library of Medicine, there are a number of symptoms that present themselves as a result of motion sickness, including increased salivation, which is the body's way of protecting the teeth from the high doses of acid accompanied by vomit. Enter olives, which contain tannins that, when released in the mouth, work to dry saliva-first eliminating the symptom and then the body's instinct to follow suit. However, the treatment is only effective during the early stages of nausea, when the salivation changes first appear.
Discover 75 easy ways to keep your family healthy.
Gargle Salt Water for a Sore Throat
Photo: Thinkstock
When you were a kid and had a sore throat, your mom likely made you gargle warm water with salt in it...and she was definitely on to something. According to Douglas Hoffman MD, PhD, author of the website The Medical Consumer's Advocate, a sore throat is an inflammatory response of the infected tissues, and the salt helps draw out the excess fluid to temporarily decrease swelling and the pain it causes. Most remedies call for a ratio of 1 tablespoon salt to 8 ounces of water, but it's always better to opt for more salt rather than less. Just keep in mind that you are treating the symptoms-not the illness. As Dr. Hoffman notes on his website: "The relief is very real, but also tends to be short-lived, since the gargle has done nothing to remove the cause of the sore throat."
Original article appeared on WomansDay.com.
