Great mechanical principles and inventions
Moderator: maixuanthanh
Post by dacung » 30 Jun 12, Sat, 12:37 pm
Here are 9 .... which show the greatness of the human mind.
1: Aircraft Radial Engine
2: Oval Regulation
3: Sewing Machines
Image[
4: Malta Cross movement -second hand movement used to control the clock
5: Auto Change file mechanism
6: Auto Constant Velocity Universal Joint
7: Gun Ammunition loading system
8: Rotary Engine - an internal combustion engine, the heat rather than the piston movement into rotary movement
9: Boxter Engine - it's cylinders lined up side by side
